Автор Тема: Локомотивы, вагоны, рельсовый материал, электроника - продам  (Прочитано 1945 раз)
Оффлайн anykey54
Приветствую уважаемое сообщество!
В связи с невозможностью построить то, что хотелось, продам много всякого хорошего добра. Практически все новое, вскрывалось для посмотреть, так как продавать и в мыслях не было, поэтому некоторые вещи без упаковки, некоторые вскрыты. Есть и бу.
Итак, начну с цифры.
NCE Power Cab 2 Amp DCC System w/Power Supply v1.65 NEW 525-25 25 - 17000 рублей НОВЫЙ
NCE’s new entry level system, the Power Cab with a capacity of 2 amps, is enough to run 3 to 4 HO locos. It offers all but a few of the features that its big brother, the ProCab has, and the price, makes for an ideal starter (entry level) DCC system. When comparing the features of all entry level systems, you will find it difficult to understand how you get so much with the Power Cab.
The Power Cab features include:
   2 amps capacity.
   4 digit address, enabling the use of the loco I.D. number eg 3801 as the address.
   Programming on the Main, (POM) type of programming. (Operations mode).
Power Cab u201cdoubles up” as a full function u201cProcab” on a NCE PP 5 or 10 amp system.
   Easy advanced consisting that allows front or rear loco number to address the consist.
   Dedicated function buttons for horn and bell. Full 12 sound functions.
   An ammeter included in the display for monitoring layout current.
   Extra optional walk around throttle
   Supports radio throttle with extra radio base station.
   Upgradeable and easily expanded with optional 3 amp Smart booster.
   All components can be used in a 5 amp system.
   Included switch mode power pack and special Power Cab UTP as shown.
The only features missing from the Power Cab are 1. Only one extra throttle can be added. 2. Only two recalls instead of 6 with the ProCab and 3. Obviously, 3.3 amps of current capacity is missing, thus preventing more than 4 operating locos at once. Still enough for a single operator.
As with the ProCab, there is no learning curve for operating the Power Cab. All operations including programming are enhanced with a 2 line display that prompts you along with menus and operating displays in plain English. No need for continually referring to an instruction manual.
The Power Cab display is similar to the ProCab display shows all necessary operating parameters in an easy to read alpha numeric display – no tiny symbols.
An ammeter is a new feature and only available on the Power Cab as the power for the whole layout comes from the Power Cab, not like in the PHP 5 amp where it comes from the booster.
The Power Cab as advertised can handle 4 operating locos with two operators all with the power pack that is supplied. As the layout grows, you can expand the system that is possible with the Power Cab.
As most layouts are operated by one person, the Power Cab can run a medium sized layout, with sound, without exceeding the Power Cab specifications. An optional radio throttle will give the freedom that is essential on a walk around layout like mine.
Hooking up the Power Cab – its so easy.
Plug in the supplied power pack to the special UTP.
Plug in the Power Cab with the special 6 conductor u201cflat” cable into the UTP’s L/H RJ12 socket with the LED on the bottom.
Connect the track and you are now ready to operate the layout or to program a decoder
NCE DB3a 5 Amp Booster Power Cab DCC #524-032 NEW - 18 000 рублей НОВЫЙ
Model DB3a 5-Amp Dumb Booster by NCE. Provides additional 5 Amps of power to an SB3a Smart Booster (sold separately - check my listings), or other 5 Amp DCC systems. Additional 5-Amp boosters may be connected for even more power handling on larger layouts.
Specifications:
•   Input 14-18vAC (50/60Hz, 5+ Amp), or 18-24vDC
•   Output 5.0 Amp (5.1 maximum continuous), 13.8 volts (factory setting)
Requires a separate power supply such as the NCE #P515 or DCC #MF615 (sold separately - check my listings). Does NOT have a programming track output.
В КОМПЛЕКТЕ 32000 рублей
Bachmann EZ Command Decoder 1 Amp with NMRA 8 Pin Plug 44916 (5 штук) - 12000 рублей за все или 3000/штука
Bachmann item number 44916. You get one pack of THREE E.Z. COMMAND 1 AMP LOCOMOTIVE DECODERS with NMRA 8 Pin Plug.
If you have questions about what this item is or how it works please visit the BachmannTrains web site for discussion.
Introduce your locomotives to the digital age with our basic 1 amp decoders; 3 per card. compatible with NMRA-compliant DCC systems; programming on the main; control speed, direction, and lighting functions; two- or four-digit addresses; 28/128 speed steps; eight-pin plug for DCC-ready locomotives
Локомотивы
N Spectrum Union Pacific (Bachmann) GE Dash 8-40C, UP #9218 85053 DCC Ready НОВЫЙ - продан
вагончики попались
N scale The Milwaukee Road passenger cars - 3-car set by Arnold Rivarossi 0557 БУ - 5000 рублей, в очень хорошей кондиции
Bachmann Spectrum Steam Set "N" No. 24122 Stationmaster Santa Fe 2-8-0 DCC-ready 24122, БУ - 10 000 рублей
ЛИМИТКА! N Scale Norfolk & Western Class J - Bachmann Limited Collector's Edition БУ - пока без цены, есть особенности
N-SCALE BACHMANN SPECTRUM GE 44 TON DIESEL SWITCHER YELLOW WITH DCC 81851 НОВЫЙ - продан
Bachmann N Scale Train Alco Rs-3 Diesel DCC Equipped #8298 64256 НОВЫЙ - 12 000 рублей
Introduced in 1950, the all-purpose, 1600-HSP RS-3 diesel locomotive had the stamina and strength for freight and passenger service yet was agile enough for yard work. With its rugged, dependable design, it’s no wonder that many of these versatile RS-3 locomotives are still working today on short lines, tourist lines, and hauling freight. Now in N scale, Bachmann’s DCC-equipped model adds digital control and versatility to your stable of locomotives.
Features include: DCC-equipped for speed, direction and lighting, dual-mode NMRA-compliant decoder, eight wheel drive, precision can motor, dual precision-balanced brass flywheels, die-cast chassis, finescale handrails, blackened nickel silver wheels, detailed exhaust stack and fan, machined brass worm bearings, prototype-specified headlights, NMRA wheel phofile, E-Z Mate Mark II couplers.
Bachmann Spectrum item number 81662 4-8-2 N Scale Steam Locomotive & Tender NASHVILLE, CHATTANOOGA & ST. LOUIS road number 555 НОВЫЙ - 14 000 рублей
Inspired by Bachmann's HO version of this model and equipped with many of the same details found in their award-winning N scale 2-8-0 Consolidation, Bachmann is moving mountains in N scale with this Spectrum® USRA 4-8-2 Light Mountain.
This locomotive performs best on E-Z Track® curves with a minimum radius of 19 inches.
Features include:
• DCC ready• precision motor• metal motor and driver axle bearings• operating headlight• separately applied stack, domes and cab• completely hidden drive train• gear drive• metal tender wheels with pickup• scale front-mounted dummy knuckle coupler (standard N scale coupler also packed separately)• detailed cab interior• separate sanding lines• separate detail parts, including bell, whistle, pop valves and handrails• builders plate• die-cast, finescale driver spokes
Рельсовый материал вразнобой - продано
Хвойный лес, 4 упаковки - продано
« Последнее редактирование: 07 Марта 2024, 08:14:26 от anykey54 »
Приветствую!
А сколько стоят ёлки? Из чего сделаны, кто производитель?
Оффлайн anykey54
// сколько стоят ёлки? - 500/пакет, там то ли 20, то ли 25 штук
// Из чего сделаны - сие мне неведомо, я сам не могу понять, похоже на пластик, но очень уж реалистично и внизу, как заточенная спичка, прочные, от дыхания не ломаются
// кто производитель - это Китай, ноунейм, покупалось на ebay
Правые механические стрелки и все елки в недолгом резерве до вечера
ручки чесались, несколько строений собрал, там оптоволокно, задумывал внутри освещение чтобы было - можно отрезать, если не нужно. Продавать такое считаю неуместным, просто подарю понравившееся тем, кто будет что-то покупать, так что выбирайте, кому чего положить к покупке. Само собой, чем серьезнее покупка, тем больше подарочек  :friends: Крыши у домиков есть, просто я их не монтировал на некоторых. Домики станционного смотрителя - там просто пылинки из коробки (на фото как будто перепачканы). Это не стояло нигде, просто собрано. Депо хорошее, ворота открываются, но можно самому помудрить, хотел сделать на сервах, чтобы открывались сами, когда подходит лок (на герконах). Есть и сервоприводы, и герконы, много всего еще есть, не до всего еще добрались руки, в выходные займусь. Еще есть несобранные здания и сооружения. Позже все будет
« Последнее редактирование: 01 Февраля 2024, 05:44:04 от anykey54 »
anykey54, Игорь, здравствуйте.
Жаль, что у Вас задумка не вышла. Но, может, расскажете, что собирались делать и как вообще дела с Хобби?
И вот отдельно заинтересовал такой Ваш текст:
Может в отдельной, теме, расскажите пожалуйста поподробнее, если не трудно.
Я как-то кидал идею о том, что могло-бы быть удобно и интересно использовать оптоволокно для проводки освещения.
Также, кажется, мы где-то обсуждали, что например в светофорчик N-ский было бы самое то провести оптоволокно.
Расскажите пожалуйста, если не трудно, хотя-бы и в этой теме: Панельная 3-э этажка с нуля из картона...  что за волокно и как в целом это удобнее реализовывать и применять.
Английские домики - класс!)
Оффлайн anykey54
Приветствую! Да все очень просто, я это уже реализовывал на одной из диорам, там у меня воришка был с фонариком в масштабе 1:72. Оптоволокно протягиваю, где-то под макетом диод, пожениваю их посредством черной термоусадки - все... фонарик светится ) Так же и тут. Получаются светильники внутри помещения, которые видно через окно. Красиво
Теперь подвижной состав. Пусть будет по номерам, чтобы легче было ориентироваться, о чем идет речь. Все НОВОЕ
Номер один. 1000 рублей
Номер два. продан
Номер три. 1500 рублей
Номер четыре. 1000 рублей
Номер пять. 1000 рублей
Номер шестьостался один 1000 рублей
Номер семь. продан
Номер восемь. 1500 рублей, коробка уставшая какая-то, вагончик в прекрасной кондиции
Номер девять. 1300 рублей
Номер десять. 1300 рублей
Покупателю трех вагонов подарок - один из этих вагонов. БУ, но в отличном состоянии (без коробок). Кто хочет забрать все 3 сразу - 1100 рублей (Санта Фе уже подарен)
« Последнее редактирование: 05 Февраля 2024, 09:36:05 от anykey54 »
Игорь! Красные гондолы Берлингтон с углем-- номера разные?
Оффлайн anykey54
Номера одинаковые
Я бы одну взял.Куда платить и как? А так же номер два и номер семь.
Оффлайн anykey54
ну тогда надо брать ))) берите, все по 1000 рублей
TOMYTEC - 2500 рублей
семафорчики, Китай, трудолюбивые руки, 10 штук по 200 рублей. Работают. Светятся
RATIO, пластик, 1200 рублей
RATIO, пластик, 1500 рублей
Вот такая 500 рублей
Флокатор на двух батарейках, 1200 рублей. Работает отлично. Есть много флока (трава) и всяких кустов, пока не добрался до них
Куда платить
Ответил в лс
« Последнее редактирование: 04 Февраля 2024, 19:44:51 от anykey54 »
